It is currently Fri Aug 22, 2025 5:29 am
 Post subject: Delete
PostPosted: Thu May 30, 2013 1:24 pm
Delete
 Post subject: Re: Delete
PostPosted: Thu May 30, 2013 6:27 pm
I'll raise you.
Double Delete
PostPosted: Thu May 30, 2013 6:51 pm
Tarnation! - Trumped again.
Just realised what the snip was. laughing6-hehe
PostPosted: Fri May 31, 2013 6:27 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
"This gap was either accidently caused by Rose Mary Woods or by a misfunctioning Uher tape recorder or deliberately by somewone who wanted to discredit president Nixon."
PostPosted: Fri May 31, 2013 6:28 am
First name: Tony
Last Name: C
City: Brooklyn
Everyone knows the way to get a thread deleted is to post goat porn!
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri May 31, 2013 9:40 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
ART not PORN!
Let's try to pull off the opposite of a thread jack. I have a bunch of mahogany offcuts from Hibdon that are essentially neck blanks but just a little short (or a lifetime supply of uke necks). I also have a bunch of mahogany blocks of various shapes from the same source. These are really nice and if I use a v jointed headstock I can do a stacked heel, or if I use a separate block for the heel, I can do a scarf comfortably. I don't really like the look of a heel made from a separate block unless it is well matched to the neck shaft. When you do a stacked heel you can ensure that all the pieces are of uniform color and the grain is running the same and that looks much nicer to my eye.
If I use a separate block, I can get a good enough color match as most of the wood in this lot is of uniform color but is there any trick for matching up the grain direction? in the rough, it is hard for me to tell what it will look like once carved and under finish. . .
Bryan Bear PMoMC
PostPosted: Fri May 31, 2013 10:44 am
Last Name: Beaver
City: Lake Forest
Delete is a subject I know very little about. Now if you want to talk stockpile I'm your guy.
Joe Beaver
Maker of Sawdust
PostPosted: Fri May 31, 2013 11:19 am
I prefer "Shred."
PostPosted: Fri May 31, 2013 12:54 pm
Take your choice:-
Delete, X-out, annul, black out, bleep, blot out, blue-pencil, cancel, clean, clean up, cross out, cut, cut out, decontaminate, destroy, drop, edit, efface, eliminate, exclude, expunge, obliterate, omit, pass up, rub, rub out, rule out, sanitize, snip, squash, squelch, sterilize, strike out, trim, wipe out.
Perhaps we should have a vote?
PostPosted: Fri May 31, 2013 5:42 pm
Last Name: Hodge
Colin North wrote:
Take your choice:-
You forgot redact! :D
Bill Hodge
PostPosted: Fri May 31, 2013 6:48 pm
Quote:
You forgot redact!
What about done blowed up?
PostPosted: Fri May 31, 2013 7:03 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Discreetly slipped out the back door.
Alex
PostPosted: Sat Jun 01, 2013 10:21 am
First name: Stuart
Last Name: Gort
The perfect delete would be to not even show up in this thread....but I can't figure out how to do it.
StuMusic
PostPosted: Sat Jun 01, 2013 10:40 am
First name: Tony
Last Name: C
City: Brooklyn
Irish exit?
PMoMC
PostPosted: Sun Jun 02, 2013 1:14 am
Last Name: Beaver
City: Lake Forest
More like mafioso exit
Joe Beaver
Maker of Sawdust
Users browsing this forum: Hock and 17 guests
